Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
starter heat shield
Old Dec 11, 2012 | 10:17 PM
ftf396's Avatar
ftf396
Default starter heat shield
how can I identify an original 71 bb heat shield from a reproduction? Is it chromed? how is it different from a sb?
Old Dec 12, 2012 | 10:14 AM
gbvette62's Avatar
gbvette62
The small block heat shield is a "sort of" triangle shaped stamped steel piece, painted black, with 2 slots in it.
The big block shield was stainless steel. They are rounded and have a reinforcing rib stamped into them, and I think just one mounting hole. The big block shield looks like a small piece of ignition shielding.
To my knowledge, the repro ones are pretty close to OEM ones.
