Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Convertable hardtop
Old Jun 13, 2002 | 09:22 PM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Default Convertable hardtop
Are the hardtops interchangeable through the years 68-75? My 71 came with the option but the hardtop is long gone. I want to replace it but I'm not sure if there is anything I should look for in particular for a 71.
Thanks in advance for any help.
Old Jun 13, 2002 | 11:16 PM
wombvette's Avatar
wombvette
Default Re: Convertable hardtop (gq82)
Totally, there is a minor trim difference in the 68.
Old Jun 13, 2002 | 11:23 PM
67HEAVEN's Avatar
67HEAVEN
Default Re: Convertable hardtop (wombvette)
Wombvette,
Congrats on 1,000. :cheers:
Old Jun 14, 2002 | 02:29 AM
Bob Jenkins's Avatar
Bob Jenkins
The '68 model hardtops did not have the chrome tips on the rear points like the '69-'75 did. Also the rear glass is dated so if you are concerned about being "correct", you may want to look for a matching date coded hardtop. :smash:
Old Jun 15, 2002 | 04:19 PM
PRNDL's Avatar
PRNDL
Default Re: Convertable hardtop (Bob Jenkins)
Which tops have the 3rd attachment point in the middle? I dont think they all do, but not sure. MJ
Old Jun 16, 2002 | 12:03 AM
gq82's Avatar
gq82
Default Re: Convertable hardtop (MNJack)
Mark, my car has that third attachment point.
Old Jun 16, 2002 | 04:35 PM
Corvettes White's Avatar
Corvettes White
Mid year thru the '69 run if I recall also there are two different sizes of pins at the front headers. And I think that some bow clamps cam with rubber and some without. But all basically the same.
George
Old Jun 17, 2002 | 07:16 AM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
Default Re: Convertable hardtop (999)
In late 69, they added the third pin in the back. I believe all the pins in the front are the same. The rear pins were of a different size in 68. Also, the front latches.....68 used an acorn design nut to lock the hardtop down. Later used rubber cushion covered pins. This would not affect the fit however. Chuck
To Convertable hardtop
