Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
generator build date
Old Jun 16, 2013 | 09:24 AM
3X2's Avatar
3X2
Default generator build date
Would a Feb 1969 generator be correct for a July 69 car? The one on the car is a 9B11 and the trim plate has L18.
Old Jun 17, 2013 | 08:33 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Probably. The NCRS allows a six month window for dates. Keep in mind the strike was on the horizon in the spring of 69.
Old Jun 17, 2013 | 08:51 AM
3X2's Avatar
3X2
Thanks Mike. My next concern is that it is a 42 amp generator and not the 61 amp called for in the shop manual and NCRS guide. The original owner doesn't remember ever changing it and I know I haven't in the last 35 years I've had the car. Is it possible to have a factory installed 42a generator on a 435 casr with TI?
Old Jun 18, 2013 | 09:33 AM
Easy Mike's Avatar
Easy Mike
I suppose anything is possible. If you are concerned with judging, go with the Judging Guide; otherwise how will you document your 42A is original?
Old Jun 18, 2013 | 06:02 PM
3X2's Avatar
3X2
Thnaks again Mike. I guess I'll try to locate a correctly numbered and dated generator. What would I use for a time frame? Engine block date? Body tag date?
Old Jun 19, 2013 | 08:32 AM
Easy Mike's Avatar
Easy Mike
Engine assembly date must predate the body assembly date. Engines were ordered in advance and on hand at St. Louis before the car started down the assembly line.
An alternator would have been ordered in advance of the body date. Use your time/build code as a reference for the alternator date.
To generator build date
