Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Automatic
Old Nov 23, 2013 | 05:13 PM
firstdaffy's Avatar
firstdaffy
2nd Gear
Default Automatic
I would like to know if an automatic transmission can be put in a 61' Corvette.? Weak knee, having difficulty with the clutch.
Any help
Old Nov 24, 2013 | 06:26 AM
mapman's Avatar
mapman
Any help
Welcome to the Forum.
Yes, a Powerglide Automatic Transmission was optional for 1961.
Old Nov 24, 2013 | 10:22 AM
firstdaffy's Avatar
firstdaffy
2nd Gear
Thanks. I didn't think an automatic Trans was available until late 60' .
Old Nov 24, 2013 | 11:56 AM
champs65's Avatar
champs65
61 corvettes came with a cast iron air cooled powerglide, but it would be better/easier IMO if you just find a long shaft aluminum powerglide with mounting holes cast into the tailhousing. Or you could fabricate a bracket to hold the shifter to the tailshaft also.
Go to the C1 C2 section of the forum, lot more active than this section
Old Nov 24, 2013 | 03:27 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...I didn't think an automatic Trans was available until late 60'...
All 53s, 54s, and most of the 55s were automatics. The standard transmission came out late in 55.
To Automatic
