C3 (69) Door Ajar switch replacement
On a side question....I have some parts I am having a hard time finding. I am looking for the seat belt grommets that go into the carpet next to the seat, and also an original style 69 handbrake with the chrome trim. Anyone know where to find them?
Thanks :cheers:
AC
AC, it seems the real problem is getting the loose plate out of the bottom of the body cavity. I think I would do a whole lot of "fishing" before I cut open that fiberglass door jamb.
Get yourself one of those little bar magnets like those in the end of small instrument screwdrivers, attach it somehow to a piece of strong twine, and go "fishing" for the plate. However you attach the magnet, make sure its secure (do a little proof testing), because if you lose the magnet down there, it's going to stay as long as the grass grows and the rivers flow. One thing you need to check before you get too far is the power of the magnet; i.e. is the selected magnet strong enough to lift the plate?.
If you have a small flexible mechanic's magnet tool that will work, so much the better. Expect to have a little frustration "diddling" if that plate is laying on or against the birdcage. If the magnet doesn't work, and I wouldn't give up on it quickly, a last resort 'fish' tool could be made from a coat hanger or stiff wire with a "hook" on it. The odds of hooking it with a piece of wire are REALLY a long shot. I haven't looked at it real carefully, but you may find the "fishing" easier if you remove the interior rear quarter panel trim, and "fish" from the top for more of a straight line shot.
When you manage to 'fish' the plate up to the switch hole, use your finger through the body mount cavity hole to line up the switch hole in the plate with the switch hole in the fiberglass, and stick a Phillips screwdriver through the switch hole into the body mount cavity to keep the plate from falling back down. Then take a nail (8 penny should work), and align one of the rivet holes in the plate and the fiberglass. Using your pop-rivet tool, hold the plate in position from the rear with your finger and install the first pop-rivet. Do a little shopping and find pop rivets that are close in appearance to the original pop rivets, and has proper length to grip the plate AND the fiberglass. Once you have one pop rivet in place, install the second pop rivet using the same procedure.
I can't see any reason why it won't work. :D
Parts...seat belt carpet grommet; I have no information on this part...Park brake handle; NOS? You can fagettaboutit. They are extinct as far as I can tell. Look for a mint used (also on the endangered list and almost impossible to find). No repro available.
[Modified by Chuck Sangerhausen, 10:25 PM 7/23/2002]
Nobody repro's the carpet grommets. Many people don't know what you're talking about when you ask for them. Your only choices are to rummage the flea markets, where you can usually pick them up for about $10.00 each, or you can try calling some of the used parts dealers. The catalog places don't have them. Buy any color you can find, as they can be dyed to match your carpet. These grommets are rubber, and are fairly big. They're about 8-9 inches long and 2-3 inches wide.
NOS E Brake handle??? I've been looking for one for years. No such animal. It's tough if not impossible to find a used one in good or even reasonable condition. I investigated trying to have the plastic chrome re-done. Couldn't find a place to do it. Best "deal" I could find was a place that would plate the ENTIRE black plastic handle, then I would have to "black out" the non-chrome areas. The cost to do the entire plastic handle was about $250.00 as I recall. Hope this helps. Chuck
Chuck G, I have the 3 x 4 plates out, but there is still part of the birdcage in the way of the switch. There is a little hole in the birdcage that you can get one finger in. This is a pic from inside the body mount opening.
I already have the interior panels off (along with the rest of the interior), but there is metal in the way there too.
Here is the damage the spinning backing plate caused.
:eek:
I think I will try Chuck S' magnet trick to get the backing plate up. On the driver's side, both rivets are broken also, but since the switch has yet to be unscrewed, I can use it to turn the backing plate to line up the holes and pop in new rivets. After the new rivets are in, there should be enough strength to get the switch unscrewed. I am not worried about the wires, as I am replacing the rear harness. For some reason, the driver's side switch pin was smashed sideways, and neither switch has worked as long as I have had the car.
On the carpet grommet issue.....what a bummer! I have my old used ones, but they are SO wavy they aren't really usable. I have a late C3 parking brake handle in there now, but it's currently missing it's button since it one day went flying out after I replaced the brake. It was a whole 6 months old. :rolleyes:
Thanks again guys. :cheers:
AC
Regarding the grommets, could you heat them up with a hair dryer and remove some of the waviness? They're pretty heavy chunks of plastic. Chuck
[Modified by Chuck Gongloff, 6:11 PM 7/24/2002]
How about lining the plate up to where it was originally rivited. then drill out one of the broken rivets. Then stick a drill bit though to hold it while you loosen the switch.
AC
and
Woohoo! :cheers:
I used the flexible magnet to retrieve the backing plate. That took about half an hour to retrieve (with one drop of the plate in there as well). I then stuck a screwdriver through the center whole like Chuck S said. Then I stuck my finger in through the backside and held it there until I could screw in the old door ajar switch to hold it from falling down. I then drilled out both rivet holes, as there were still pieces of the rivets in there. After that I put in new rivets, and that's it! The drivers side was easier, as all I had to do was drill out the old rivets and install new ones to hold the plate strong enough for me to get the old switch out. I am now all set for new switches (and later paint)! :D
AC
Looks like the right side switch hole got "wallered out" a little. Before paint, you may want to consider removing the switch (again?), stripping the area around the switch hole, grinding the damaged area, masking off the rivet heads, and applying some little pieces and mat and resin over the damaged area.
Before I applied resin, which could ruin the switch threads, I believe I would carefully apply grease to fill the threads. Don't get ANY grease on the surrounding fiberglass, or your new repair won't stick. You will probably have to re-drill the switch hole afterwards, so better figure out how to locate the center of the hole, and buy a proper size hole saw (I think you can get one that small).
After the hole is re-drilled, hand sand the area to smooth and blend the repair until it is invisible. A little body filler may help. You could simply use body filler on the damaged area, but I am not sure the body filler would stay for the long haul.
