Need help with loose steering column!
Also, I noticed on the fuse box a row of empty areas on the right-hand side. Do fuses go there and what size should I buy?
Thanks.
There is no corresponding bolt to use for comparison. A car show friend who restores old cars suggested I get an allen bolt from the hardware store. I went there yesterday and a guy tried several screws and bolts but none fit right except for this phillips head screw.
I'll keep trying. Thanks.
On later cars, two bolts attach the mounting "wings" on the steering column to a stamped steel support mounted behind the dashboard. This stamped steel support has two nuts welded in position to receive the steering column bolts. These bolts are indeed "screws"...machine screws or cap screws that is.
Later cars use 3/8NC X 1" long cap screws and I wouldn't be surprised if they were the same on midjeers. Go to an auto supply store (NOT HOME DEPOT) and get at least Grade 5 fasteners (bolts, screws, whatever) for this application.
