Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Early 70 Carburetor Question
Old Jan 13, 2003 | 02:40 PM
00Nassau's Avatar
00Nassau
St. Jude Donor '11
Default Early 70 Carburetor Question
I am looking for a Rochester Quadrajet Carb No. 7040207, dated before 2-20-70, to replace the incorrect one currently on my car. If I go back six months into 1969, the number would have then been 7029207. Would this pass an NCRS judge as long as it is not over six months prior to my build date?
Old Jan 13, 2003 | 02:50 PM
JohnZ's Avatar
JohnZ
Default Re: Early 70 Carburetor Question (00Nassau)
Nope, to be correct and get full point credit it has to be the 7040207; the 7029207 is only correct for a '69.
:cheers:
Old Jan 13, 2003 | 02:52 PM
00Nassau's Avatar
00Nassau
St. Jude Donor '11
Default Re: Early 70 Carburetor Question (JohnZ)
Thanks, JohnZ.
I figured that was the answer, but I thought I would ask.
Old Jan 14, 2003 | 02:01 AM
PRNDL's Avatar
PRNDL
You might want to check with Juliet. She has a somewhat early 70, and I believe she learned that Carter built some Qjets for the 70s. They might be easier to find than the right Rochester. MJ
Old Jan 14, 2003 | 02:19 PM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: (MNJack)
the original equiptment q jets built by carter still use the GM numbers except the replacemant ones sold thru the auto parts which used carter numbers. :chevy
Old Jan 14, 2003 | 04:34 PM
ED DINAPOLI's Avatar
ED DINAPOLI
NCRS requires Carb number be correct and the date be no more than 6 months prior to the build date.
Ed
To Early 70 Carburetor Question
