Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
A question on the steering box this time
Old Feb 2, 2003 | 08:41 PM
70BBvert's Avatar
70BBvert
Default A question on the steering box this time
Got most of the front suspension & steeging back together on Sat morning. Sunday I started cleaning up the steering box & pitman arm. Glass beaded the pitman arm & degreased the sterring box and cleaned it up ith a wire brush.
The casting number on the pitman arm matches the AIM but not the steering gear, the AIM has a part # of 7807759. The # cast into the main housing is 5877848. Does this matter? Also it had a blue paint stripe not a yellow daub as I had read in a couple of books. Forgot to take a pic before I cleaned it up :bb
Here's a pic of the steering gear & pitman arm cleaned up though.
What finish should they have? Cleaned off black paint form the steering gear. Both black? or Natural?
Jim
Old Feb 3, 2003 | 01:39 AM
SWCDuke's Avatar
SWCDuke
Default Re: A question on the steering box this time (70BBvert)
Keep in mind that the AIM calls out END ITEM part numbers, not casting numbers. Also, I believe that the steering gear arrived at the plant with the pitman arm attached, so this "assembly" would have a unique part number.
For service, the steering gear and pitman arm were available separately, not a subassembly, so the steering gear and pitman arm will each have a unique part number that won't match what's in the AIM.
Same applies to the steering linkage. It arrived at the plant as an assembly, so the linkage assembly and steering gear/pitman arm assembly were the two major pieces. Beyond the steering damper or power steering boost cylinder, the rest of the part numbers called out in the AIM in the steering section are integration hardware.
Duke
Old Feb 3, 2003 | 11:00 AM
Robd's Avatar
Robd
Jim,
I have been doing a lot of research over the last month on chassis part markings. The one thing I have found out constantly is inconsistence. We know for sure, parts were marked for various reasons, i.e. Inspections for torques, physical being, measurements, etc. Effort was made to use the same color and location of paint daubs. However they did vary from worker to worker at various times for unknown reasons. I would duplicate the markings you found understanding that shades of colors do change through the years even more covered with grease, oil, dirt and grime for thirty years.
After all most have seen the "L" steering box marking story!
"A while back, that there was a funny story on the NCRS forum which told of an old Corvette assembly plant worker who shocked the spectators at an NCRS event when he responded to a query about the "L" on a steering box -----he said it meant "leaker". This story, although funny, is true."
Old Feb 3, 2003 | 02:40 PM
JohnZ's Avatar
JohnZ
The casting number on the steering gear only identifies the raw casting itself; that casting was machined differently and made into numerous end-item steering gear assemblies, with different internals, each of which carried a different part number for the complete assembly. Hardly any casting numbers ever match the finished part number, although occasionally a forging number (as on the forged pitman arm) matches the finished part number, as forgings are generally machined into only one finished part. :thumbs:
To A question on the steering box this time
