Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Battery Disconnect Switch
Old Feb 5, 2003 | 01:54 PM
Yellow6t7's Avatar
Yellow6t7
Default Battery Disconnect Switch
I'm sure this is a dumb question for all the experts. But I really would like to undersatnd this. Why is the battery disconnect switch attached to the ground side battery terminal and not the positive side? It seems to me, if the positive was disconnected there would be no chance creating a short.
Old Feb 5, 2003 | 02:08 PM
JohnZ's Avatar
JohnZ
Default Re: Battery Disconnect Switch (RESPO6T7)
Because when it's on the ground terminal, it totally eliminates the ground path back to the battery, which makes it impossible to create a short or make a spark anywhere in the car, even if you drop a wrench and one end hits the positive terminal and the other end hits the engine or the frame. If you put it on the positive terminal and drop a wrench on it, the ground path back to the battery still exists, and you can still get a direct short/spark. :thumbs:
[Modified by JohnZ, 2:09 PM 2/5/2003]
Old Feb 5, 2003 | 02:21 PM
Mac's Avatar
Mac
You're right- you could easily disconnect on the positive side (in fact, some of the old British cars did, but they were 'positive ground' and that's a whole other story) but the theory for why it's on the negative side makes sense.
DC (direct current) works because there is a difference in potential between negative and positive. In order to function as DC, there must be a complete circuit or path for the current to flow. If you disconnect either side of the battery, it will interrupt the circuits.
The theory for disconnecting the negative versus the positive is this. The negative side of the battery is electrically 'common' (connected) with every metal part of the car. The positive side goes (directly or indirectly) only to the specific componants it powers. If you remove the negative side, it removes any possibility of accidently reconnection by removing every metal part of the car from the circuit.
Does that help? :cheers:
Old Feb 5, 2003 | 04:16 PM
Yellow6t7's Avatar
Yellow6t7
Default Re: Battery Disconnect Switch (Mac)
Now that's an explanation that makes sense. :cheers:
To Battery Disconnect Switch
