Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
68 verse 69 horn button differences
Old Feb 8, 2003 | 08:57 AM
R1234's Avatar
R1234
Default 68 verse 69 horn button differences
Can someone point out the differences between a 68 horn button and a 69?
Old Feb 9, 2003 | 03:10 PM
Doc Rebuild's Avatar
Doc Rebuild
Default Re: 68 verse 69 horn button differences (68rdstr)
Sir,
The differences between these horn cap assemblies are as follows:
A 1968 standard or telescopic steering column Horn Cap assembly is identical to and will this interchange with a 1969-1975 STANDARD steering column Horn Cap assembly. If you have a 1969-1975 TELESCOPIC steering column, the Horn Cap Assembly is larger in diameter and will NOT fit any 1968 steering column.
Geoffrey Coenen
NCRS #2473
NCM Lifetime #105
Precision Valley Corvette Museum Charter Member #20 (I think)
Vettehead #18-1
Retired #1 56, 63, 67, 68, 68, 69, 75, 99 and I want more! :D
PS I would like a real nice 68 Tele column for one my 1968’s – it will make exit and entry easier.
Old Feb 9, 2003 | 07:04 PM
R1234's Avatar
R1234
Default Re: 68 verse 69 horn button differences (Doc Rebuild)
Thanks Doc!
I believe the horn button I have is a 68 and was just wondering if there was a way to identify.
I know what you mean about sliding under the steering wheel on a 68 with a standard column.
To 68 verse 69 horn button differences
