Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Dist RFI Shield Label
Old Mar 4, 2003 | 10:14 PM
RMS73's Avatar
RMS73
Default Dist RFI Shield Label
What is the wording on the label on the inside of the shielding covering the points? Know of a place/person that I could get a replacement label?
Roger
Old Mar 5, 2003 | 01:59 AM
GDaina's Avatar
GDaina
Default Re: Dist RFI Shield Label (RMS73)
I wasn't aware there was a decal inside the shielding
Old Mar 5, 2003 | 02:09 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
Default Re: Dist RFI Shield Label (GDaina)
If yours has a sticker under it now, try posting a picture of it for us.
Old Mar 5, 2003 | 11:58 AM
RMS73's Avatar
RMS73
Default Re: Dist RFI Shield Label (Desertdawg)
The printing on the label washed off when I was washing the two shield pieces. The label is about 5/8" wide and 1-1/4" long. The background is/was white and the printing was black. The verbage was about 'the shielding was for RFI shielding of the points'. The letters were about 1/16" tall and I think there were four lines.
Roger
Old Mar 7, 2003 | 12:24 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
I have never seen one of these either. I did a search for it and couldn't find anything. If you do find it, be sure to post a picture of it for us.
Old Mar 10, 2003 | 08:23 AM
Rowdy Rat's Avatar
Rowdy Rat
Veteran: Marine Corps
Roger,
I pulled the NOS set of RFI shielding I have from storage the other day... The wording on the label is as follows:
This shield reduces ignition interference in vehicle radio.
To replace contact set: For adequate clearance use 1931988 (D106P) or 1966294 (D112P) as specified. See Delco Remy bulletin 6724.
Hope this helps.
Regards,
To Dist RFI Shield Label
