Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
NOS '64 amp gauge
Old Mar 22, 2003 | 11:26 AM
sparkplug99's Avatar
sparkplug99
Default NOS '64 amp gauge
I have pulled the gauge cluster from my '64 to replace the gauges with NOS.
The original amp gauge hardly ever moved off center to show charge or discharge, that's the reason I am replacing it. The new gauge is off center to the left before installation. Should the NOS amp gauge needle be in the center before installation? If so, how do you center it? Or does it center up after installation and the guage has power to it? The needle moves freely in either direction but always comes back to slightly left of center. Thanks for the help.
Old Mar 23, 2003 | 08:05 AM
jerrybramlett's Avatar
jerrybramlett
Default Re: NOS '64 amp gauge (sparkplug99)
Yes.
The needle is pressed on the gauge shaft. You can usually pull it straight off with your fingers. However, you must be careful. It is very fragile. Do not twist it. Do not try to use a grabbing tool like needle-nose pliers or you will probably crush it. Once off, you can re-install it in the center position. You don't have to mash it on very hard.
No.
Old Mar 23, 2003 | 10:16 AM
sparkplug99
Default Re: NOS '64 amp gauge (jerrybramlett)
Thanks for the help. You told me what I didn't want to hear but knew I was probably going to have to do. I'm going to try to remove the needle and move it, if I mess it up I have me old gauge to fall back on.
Thanks again.
To NOS '64 amp gauge
