Uni-points vs. seperate condensor
Gentlemen,
I'm working on a tune-up on the 74, and the points and condenser I got at Pep Boys is a so-called "Uni-points" where the condenser is integrated to the points assembly.
What I pulled out of the distributor is a separate condenser from the breaker points.
So I suppose that the black wire that went from the old condenser to the old points assembly is no longer needed with the Uni-points.
But there's also a black wire connecting the vacuum advance diaphram to a screw on the old condenser, and the new uni-points assembly does not have this screw. Is this simply a ground wire? On the new uni-points condenser, I connected this wire to the mounting screw - hopefully in a fashion where it's out of the way of the rotating part of the distributor.
What are your thoughts? Is that appropriate? Or am I mixing up parts inappropriately?
Thanks, GM
Thanks, GM
Cruise-In I Veteran
Cruise-In II Veteran
that extra wire is a ground and there is normally a ground wire from the vac adv screw to the breaker plate but these break off over time and this is a replacement :chevy
