Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
C3 Speedo Cable lube
Old Apr 15, 2003 | 10:26 AM
Red69's Avatar
Red69
Default C3 Speedo Cable lube
Anyone have any recommendations on what to use and how to effectively "lube" a speedo cable
Thanks :flag
[Modified by Red69, 10:27 AM 4/15/2003]
Old Apr 15, 2003 | 03:24 PM
JohnZ's Avatar
JohnZ
Default Re: C3 Speedo Cable lube (Red69)
Use speedo cable lube - it's specially made for speedo and tach cables, and is made with graphite; you can find it at most auto parts stores, and Corvette Central carries it as 'Kable-Ease" lubricant. Don't use chassis grease, especially if you drive in cold weather. Best way to lube it is to disconnect it at the speedo end, remove the core from the casing, wipe it down to clean off the old lube, apply the new graphite-based lube, and re-insert it; you may have to disconnect it at the trans to re-engage the cable in the end of the plastic driven gear. :thumbs:
[Modified by JohnZ, 3:27 PM 4/15/2003]
Old Apr 15, 2003 | 06:49 PM
Red69's Avatar
Red69
Default Re: C3 Speedo Cable lube (JohnZ)
Thanks -I ask for some "cable-lube" at the local AP store and they said just use grease which I know is WRONG! Thanks for the tip and source! :flag
To C3 Speedo Cable lube
