Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
69 Map-pocket
Old Apr 18, 2003 | 10:35 AM
Red69's Avatar
Red69
Default 69 Map-pocket
My map pocket needs reworking... I just received a set of new springs for it... does any one have a PIC of the back side of the dash pad they could share? Mine was previously repaired by BUBA... and I was wondering how the springs were originally set up.... (ie grommets, wire, ect...)
:flag
Old Apr 29, 2003 | 01:34 AM
kaiserbud's Avatar
kaiserbud
Default Re: 69 Map-pocket (Red69)
I have my dash out - it is a 69. Here are a few pics - Hope this helps.... :cheers:
[Modified by kaiserbud, 12:52 AM 4/29/2003]
Old Apr 29, 2003 | 11:11 PM
Red69's Avatar
Red69
Default Re: 69 Map-pocket (kaiserbud)
Thanks. Those are really helpfull. Are the springs connected through the gromit....?? and the pin and clip are there to keep it from backing out? or is the spring actually connected to the pin/stud?
Thanks again! :flag
Old May 10, 2003 | 03:25 PM
kaiserbud's Avatar
kaiserbud
Sorry for amny delay in responding....
I just checked my dash pad - the springs actually hook into the grommets. It appears that the pins/clips are there to only fill the hole and prevent the spring from coming out of the hole. :cheers:
To 69 Map-pocket
