Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
1978 Build Sheet?
Old Mar 15, 2004 | 06:18 PM
e071612's Avatar
e071612
2nd Gear
Default 1978 Build Sheet?
Hi, I’m a relatively new 'vette owner with a question. I’m trying to find a copy of the build sheet for my 1978 ‘vette so I can restore it. The NCM only has them for 1981 and later, and I’ve had no luck searching the Internet. Any ideas, please? Thanks in advance.
Mike
Old Mar 15, 2004 | 08:42 PM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
Default Re: 1978 Build Sheet? (e071612)
If you 78 is like earlier sharks, you should find a copy glued to the top of your gas tank...usually on the drivers side. You won't find a copy through GM or any other source for any St. Louis built Corvette....just Bowling Green built cars. Chuck
Old Mar 16, 2004 | 09:01 AM
e071612's Avatar
e071612
2nd Gear
Default Re: 1978 Build Sheet? (Chuck Gongloff)
Chuck - Thanks for the info! Mike
To 1978 Build Sheet?
