Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
1966 AIR pump
Old May 31, 2004 | 12:46 AM
orono64's Avatar
orono64
Default 1966 AIR pump
There are a couple of thin carbon (I think) discs that the pump vanes slip on on each end of the rotor. Anyone know where I can get new ones?
Old May 31, 2004 | 10:33 AM
JohnZ's Avatar
JohnZ
Default Re: 1966 AIR pump (orono64)
That's a carbon seal disc - you might try Bill Hodel in Massillon, Ohio, (330) 832-0871; it's a lot simpler to just "gut" the pump (remove the vane assemblies), at which point it just becomes an idler pulley but appears to be fully functional. The most common pump failure mode is vane seizure - no vanes, no seizure.
Old May 31, 2004 | 11:06 AM
orono64's Avatar
orono64
Default Re: 1966 AIR pump (JohnZ)
Thanks JohnZ, I was looking for the number of the guy in Ohio. I like your logic about the function of the pump. In a way, I wish this restoration didn't have the AIR system. It would make life easier but it's kind of neat to see the different stuff under the hood - organized chaos.
Bill
To 1966 AIR pump
