Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
AFB vs. WCFB Choke Parts Interchange ?
Old Jul 5, 2004 | 01:36 AM
RugHead's Avatar
RugHead
Default AFB vs. WCFB Choke Parts Interchange ?
Can someone explain what, if any, interchange there is between WCFB & AFB electric choke parts? I have a WCFB that was converted to manual and I want to re-fit it with the correct electric parts. Seems like I see a lot of them like that, but I'm not finding parts readily available other than the coil/cover. What are my options? Thank you.
Old Jul 5, 2004 | 12:22 PM
JohnZ's Avatar
JohnZ
Default Re: AFB vs. WCFB Choke Parts Interchange ? (RugHead)
A WCFB with an electric choke must be some sort of aftermarket conversion; all WCFB's originally had hot-air chokes with a tube from the passenger side exhaust manifold.
Old Jul 6, 2004 | 08:05 PM
RugHead's Avatar
RugHead
Default Re: AFB vs. WCFB Choke Parts Interchange ? (JohnZ)
Sorry, my error. Not sure what I was thinking there... You are, of course, correct.
So, I have a new air tube and the black cover that it connects to, but what I'm looking for are the parts the cover mounts to - the housing and the little piston & stuff that drives the linkage and moves the butterfly. Any interchange or source for these new, or is my only option finding a parts-carb WCFB?
Thanks.
Old Jul 6, 2004 | 08:46 PM
JohnZ's Avatar
JohnZ
Parts carb, or try Bob Kunz at (314) 845-2566; he's the Carter "guru".
To AFB vs. WCFB Choke Parts Interchange ?
