Anyone know of good shop to fix a blown rear-end on a 02 Z?
A buddy of mine was at the drag strip the other night and blew his rear end on the 5th run on street tires??? I quess it was wheel hopping pretty good when it went.
From: We are living in a Bazzaro World everything is upside down half ass backwards !
CI 4-5-6-7-8-9 Veteran
St. Jude Donor '06-'07-'08 & '12
Kevin At HP performance corvettes in mundelein link in my sig.
Dan at Flp in naperville .
Rick vette tech 81 on the forum
three good choice's depending where your located .
if it's still under warranty contact Kevin he also works at Libertyville chevy .
Depends on the damage. Output shafts can be replaced. Any case damage and you will be buying a whole new diff. I blew up an after market diff and chewed up the ring gear on a second. I spoke to Chuck Mallett and recommended using a stock Z06 diff which you can get for about $1,200 (includes shipping) from GM Parts Direct. Buying individual pieces will cost much more!
Dan at FLP in Naperville,(1-877-357-2946) He will set you up as he is a drag racer a does all the big guns in the area and he is close to you, Good luck.
