Chicagoland window tint installer needed
Any of you guys know good window tint installer in Chicagoland to work on my C6. North Suburbs would be great. Thank you.
CHICAGO CREW !
Location: We are living in a Bazzaro World everything is upside down half ass backwards !
CI 4-5-6-7-8-9 Veteran
St. Jude Donor '06-'07-'08 & '12
contact Kevin or craig at HP PERFORMANCE CORVETTES IN MUNDELEIN they have a window tinting guy that works out of there shop .
1-847-949-vett link to there site in my sig I have seen his work he does a very good job and he seems to be reasonable
If you dont mind traveling to the city (Logan Square area), a bunch of the guys from the Lexus board are using a guy that charges between $120-140 to do most 4 door sedans. He does excellent work and has a lifetime warranty. He did my GS last fall for $120 whereas every other shop I called wanted anywhere between 200-300.
Cruise-In III Veteran
Sunset Glass Tinting in Downers Grove does an excellent job...they've done a number of Vettes on the forum, including mine. 630-971-1700, ask for Brad.
LOL, thanks for the words of faith
The guy I used had it done in no more than 2 hours. I walked down the street for some breakfast, when I got back he had all the sides done and was working on the rear, took him a little longer to do that cause its one piece and he said that Lexus uses very thick defroster lines and its a little extra work to get the air pockets out.
I'd recommend him to anyone
