Great Lakes Illinois | Indiana | Iowa | Michigan | Missouri | Minnesota | Ohio | Wisconsin
clutch problem
Old Jul 8, 2007 | 10:23 PM
NICEDRV's Avatar
NICEDRV
Default clutch problem
I have a Z06 clutch in my vert for the past 2 seasons and now I have a little problem. The problem has happened twice.
Shifting from 1 to 2 the clutch peddle will NOT return and I have to pull it back with my foot. I will change the fluid and see if that helps.
Anyone else have this problem?
thanks for the advice
Old Jul 8, 2007 | 10:42 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
I have never had this happen to me, however, know a few people who it has. Some have said changing the fluid helps... is it only happening when you are shifting at high Rpm's?
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
nope sorry
i just thought your windshield might have been duck taped by THE CLUTCH
Old Jul 8, 2007 | 11:34 PM
RandyVettes's Avatar
RandyVettes
Life's Short. Drive Hard.
Cruise-In VII Veteran
St. Jude '03-'04-'05-'06-'07-'09
Suck the reservoir dry with a turkey baster and refill with new fluid. Pump the peddle a bunch of times, or take a ride. Repeat Repeat Repeat until the fluid stays clear.
Old Jul 9, 2007 | 12:01 AM
JimBacus's Avatar
JimBacus
Got LAPS?
St. Jude Donor '06
You should be doing this all the time...
Old Jul 9, 2007 | 07:38 AM
ipmtim's Avatar
ipmtim
Cruise-In VIII Veteran
St. Jude Donor '06
Nicedrv,
I have a C6Z and the problem you describe is a common one when the clutch fluid heats up. If you go to the C6Z forum and search for "clutch fluid change" there are many posts on it. I haven't had the problem, but I change my fluid out any time it starts to get dark.
Good luck,
Tim
Old Jul 9, 2007 | 10:51 AM
NICEDRV's Avatar
NICEDRV
Yes it only happens at hight RPM's
I was told it was only happening in the Z06's and that is why I mentioned I have a Z06 clutch.
Thanks Randy for the link.
Old Jul 9, 2007 | 11:09 AM
DPG's Avatar
DPG
St. Jude Donor '06
yup, used to happen to me all the time with the hard high rpm shifts. Then I started doing the fluid change and its helped alot. It only stuck after doing a couple hotlaps at the track.
To clutch problem
