Great Lakes Illinois | Indiana | Iowa | Michigan | Missouri | Minnesota | Ohio | Wisconsin
Recommendations on iPod integration
Old Aug 19, 2007 | 12:19 PM
BMcD-Z06's Avatar
BMcD-Z06
Default Recommendations on iPod integration
Chicago area folks - Anybody out there installed a good iPod interface that integrates with the factory radio? I see one out there from www.usaspec.com that looks well integrated. If you know of a trustworthy place to get something like installed I'd appreciate input.
Thanks!!
Old Aug 19, 2007 | 12:55 PM
johnnyvettes's Avatar
johnnyvettes
CHICAGO CREW !
From: We are living in a Bazzaro World everything is upside down half ass backwards !
CI 4-5-6-7-8-9 Veteran
St. Jude Donor '06-'07-'08 & '12
contact Greg (pentavolvo)& Dave (DPG) he is the chicago crew stereo guru
http://forums.corvetteforum.com/member.php?u=172235
Old Aug 19, 2007 | 02:07 PM
BMcD-Z06's Avatar
BMcD-Z06
Thanks!! He's right down the road from me!
Old Aug 19, 2007 | 10:44 PM
birch64's Avatar
birch64
I use THE Monster® iCarPlay™ Wireless 200 FM Transmitter with AutoScan cost 99.00 at best buy works great......and i can take it from car to car.
Old Aug 19, 2007 | 11:24 PM
TOBASCO's Avatar
TOBASCO
CI 2-4-5-6-7-8-10-11-12 Vet
NCM Ambassador
St. Jude Donor '08-'11-'13-'14-'15
Originally Posted by johnnyvettes
contact Greg (pentavolvo) he is the chicago crew stereo guru
Both Dave and Greg are great guys. Whether they do the install for you or you just want some good advice, they're there for you. Corvette bretheren.....a great thing!
Old Aug 20, 2007 | 01:31 PM
BMcD-Z06's Avatar
BMcD-Z06
Thanks for the info guys!
Birch64 - I have the previous gen Monster FM transmitter and it works OK at best. I found that turning Sound Check off on the ipod helped with the output. Any other tricks you know of to get the best sound?
Thanks!
Old Aug 20, 2007 | 02:34 PM
Fuzzy Walnuts's Avatar
Fuzzy Walnuts
Thanks!
Yeah, change out the head unit and go with a direct input. FM modulators suck for sound quality.
Old Aug 20, 2007 | 02:41 PM
DPG's Avatar
DPG
St. Jude Donor '06
or go with a hardwired fm modulator. It basically plugs into the radio antenna, this way you get a better signal. Not the best, but better than just the regular fm mod. But its been basically hit or miss with the fm modulators. Some get lucky, most don't.
Old Aug 20, 2007 | 08:25 PM
SupermanZ's Avatar
SupermanZ
Cruise-In VIII Veteran
Cruise-In IX Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11
When it comes to stereo, lights or just about anything electrical on a car, you have to talk to these guys, they know their stuff. They hooked up an ipod for me and I never listen to the radio anymore unless there is a Cubs game on.
Old Aug 21, 2007 | 12:21 AM
FrankPunz's Avatar
FrankPunz
I have a 99 coupe and used a product from mp3yourcar.com. It hooked up through the wire jack in the rear storage space. If your car did not have the jack in the trunk a gm or aftermarket cable is needed and is connected into the wiring harness under the passenger feet area carpet to the right of the ecm. It works great and i have the cable exit under the pull out ash tray, the cable tucks away unseen when ipod is removed. Just an idea worth looking into.
Old Aug 21, 2007 | 06:50 AM
MVR 155's Avatar
MVR 155
Cruise-In XI Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
I just installed the Peripheral ipod2car in my Z06..... this unit was recommended by Greg and Dave, it works great and a breeze to install (you must remove factory head unit from car), if your not comfortable with installing yourself Im sure these guys can get you set straight. I have seen photos of a bunch of different installs they have done from mild to wild
Old Sep 3, 2007 | 07:46 PM
yankee0304's Avatar
yankee0304
St. Jude Donor '07
Will,
I agree that FM modulators suck, and sometimes it is better to swap head units with a direct input depending on what the individual would like to accomplish.
Speaking only for myself, I didn't wish to spend the money to upgrade my head unit, though I could have, even with the OnStar service that I have. For myself, it wasn't financially feasible to upgrade. I'd much rather do a couple of minor upgrades to my factory Bose system, like install the Bose Amp.
I did install a Peripheral iPod integration kit today (in my '05 Impala), and it works great, even with OnStar. For those with the CD Changer and OnStar, you'll probably have to decide which one you prefer to have available for you to use.
Dave, thanks for your recommendation and time on this one, I really appreciate it!
Old Sep 4, 2007 | 09:36 AM
DPG's Avatar
DPG
St. Jude Donor '06
No problem Brendan. Glad it worked out for ya.
Now that I have a little more time. I can start looking for a solution for that merc of yours.
To Recommendations on iPod integration
