It's been a while since I had done this, and the vette is still out at the shop in storage.
But I seem to remember that there is a little clip or something that has to be slid back to release it from the ball joint that holds it? Does that sound right?
SAWZAW!!!! Actually, I too think there is a clip you slede out and it should pop off!!
yup, there are black clips on both sides of the shock. Just get a screw driver and pry it straight out to the side. You don't need to pull it off all the way. But make sure you have something to hold up the trunk especially if you have the coupe hatch. It's gonna be heavy.
