Great Lakes Illinois | Indiana | Iowa | Michigan | Missouri | Minnesota | Ohio | Wisconsin
WMC - What went wrong
Old May 24, 2009 | 12:27 AM
80sRule's Avatar
80sRule
Default WMC - What went wrong
The driver's rear hose has a leak only evidenced under pressure. I can get it to squirt a bit when I step on the brakes. It may just need to be tightened but I already have a set of new rear hoses that I didn't get around to installing last year(d'oh), so I'm gonna put those on tomorrow, then see how it goes for a while before any long trips.
As far as paint damage, no brake fluid got anywhere on the body, and only the very inner edge of the wheel had a little clearcoat cloudiness. I was very lucky.
Thanks to all who helped me out; and special thanks to Don for following me home.
Old May 24, 2009 | 07:35 AM
slolane's Avatar
slolane
CI 7-8-9 Veteran
St. Jude Donor '07-'08 & '12
Happy to do it Casey I am glad it wasn't to bad
Old May 24, 2009 | 10:22 AM
VetteTech81's Avatar
VetteTech81
It looks like it was leaking from the banjo connection? What kind of crush washers were used?
Old May 24, 2009 | 12:29 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
DANG!
Old May 24, 2009 | 03:56 PM
80sRule's Avatar
80sRule
Yeah it was leaking from there. The washers I assume were stock 1987, and appeared to be steel or aluminum.
The new hoses(got a set of 4 new Goodridge hoses last year for $50, didn't get around to it until now though...) came with copper crush washers and they work so far so good.
Old May 25, 2009 | 01:59 PM
08C6Vert's Avatar
08C6Vert
Glad you made it home safe. Sounds like the new booster exposed some hidden issues... Lloyd
To WMC - What went wrong
