Great Lakes Illinois | Indiana | Iowa | Michigan | Missouri | Minnesota | Ohio | Wisconsin
Need Help in Cincinnati....
Old Jun 15, 2009 | 02:46 PM
HMannini's Avatar
HMannini
Cruise-In X Veteran
St. Jude Donor '09
Default Need Help in Cincinnati....
I bunged up the threads on my gear shift lever so I decided to use a die to clean them up but I managed to break it off right where the threads start!!!! Does anyone know a place I can take it to get it threaded, I kinda like it shorter anyway.......
Old Jun 15, 2009 | 03:15 PM
DM VETT's Avatar
DM VETT
Try D&E Machine Shop in Lebanon.
Old Jun 15, 2009 | 07:38 PM
HMannini's Avatar
HMannini
Cruise-In X Veteran
St. Jude Donor '09
OK thanks..
Old Jun 16, 2009 | 09:36 AM
DM VETT's Avatar
DM VETT
Ask for Kent the owner. Tell him Dave from Precision sent you.
Old Jun 17, 2009 | 10:18 AM
DALE C's Avatar
DALE C
If it is a stock shifter and you cant fix the threads I will trade you the bad one for a good one if you want to make the drive to Dayton.
Good luck, Dale
Old Jun 17, 2009 | 01:16 PM
HMannini's Avatar
HMannini
Cruise-In X Veteran
St. Jude Donor '09
Good luck, Dale
That is a most kind and generous offer, Thank You very much. Fortunately I have a creative mechanic and he was able to drill a set screw into the remaining shaft and shift ball and now I have an automatic short throw shifter, it's really cool and I like it better than it was before.
To Need Help in Cincinnati....
