Warmer weather projects?
Not able to warm up the garage with my kerosene heater (open flames and gasoline fumes do not mix) and it has been so dang cold and nasty lately that I just have not felt like doing it. Santa did not bring me my Eden Pure garage heater either
I also have a small pile of goodies I have bought from vendors, Forum members, Craigslist and that big on-line auction site.
How bout you folks? What's your first project before hitting the streets this Spring?
XKR - Replace primary timing chain tensioners and guides (secondaries were changed for updated ones at dealer by previous owner), timing and cam chains, cover seals, spark plugs and valve cover gaskets.
Vette - Finish putting it back together. Need to put the intake on and get all buttoned up from the head gasket replacement.
740i - Get the rust blasted and get paint fixed. Also repair seam rip in drivers seat leather. Giving to dad after that.
Neon - Get ready to sell. Replacing with a 750iL or S600.
CB750 - Repaint chain guard, get dent in tank (from previous owner) paintlessly removed, new front tire, new gel battery. Polish some side cases if I have time.
GSXR1100W - Front fork seals, new throttle cable. I never ride it, it's way too much power for my skill level, so it's low priority.
ALL - Change all fluids.
Goldwing oil change and new tires before the long trip west this summer
Seems to be a c6 thang
Its pretty cheap and ez fix just takes some time. Like you said waiting for it to warm up a bit I have the parts
- then - a moment of silence for a short riding season
Ok over that - now start to dig out the car from back of the garage.
2. Installing BBK Shorty Headers
3. Rear Tires.
Should take about a month combined. Hopefully the roads will be clean by then.
Avalanche - Fix the small bit of surface rust in the fender. I will probably Zaino the truck (may need to recruit some zaino experts for this).
Then the next step is to fuel them up and drive them.
