Great Lakes Illinois | Indiana | Iowa | Michigan | Missouri | Minnesota | Ohio | Wisconsin
Ebcm help please
Old Jul 23, 2025 | 12:51 PM
JM76Miller's Avatar
JM76Miller
Cruising
Default Ebcm help please
Anyone in the Milwaukee, WI area that would be willing to help with the re solder fix. I am not handy and have been unemployed for a while now. May have to sell the 02 z06 if I can’t find a job and want it to not have the lights on the dash. I’ll buy lunch
Old Jul 24, 2025 | 08:23 AM
Joe Scafide's Avatar
Joe Scafide
Default Emcm
Did u pull codes ? Mine was bad battery
Old Jul 24, 2025 | 12:27 PM
JM76Miller's Avatar
JM76Miller
Cruising
I did and well the battery turned out to be bad. I did replace it with a slightly better battery. That was new and same problem.
Old Jul 24, 2025 | 12:38 PM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
I would also post up in C5 tech, will reach more C5 folks.. hope you can work it out
https://www.corvetteforum.com/forums/c5-tech-1/
Old Jul 26, 2025 | 07:20 PM
JM76Miller's Avatar
JM76Miller
Cruising
Replace the battery and codes were pulled
Old Aug 6, 2025 | 08:33 AM
Joe Scafide
Default ebcm
you must charge your new battery ?
To Ebcm help please
