Help Forum How To | General Corvetteforum Questions | Feedback
I have a problem with the forum
Old Mar 22, 2005 | 09:46 AM
shopman1's Avatar
shopman1
Default I have a problem with the forum
I can enter a thread however I can edit it. I can't respond to others. And all the advertisements have disappeared on the left.
What happened. Do others have the same problem? I logged out and in, no help.
shopman1
Old Mar 22, 2005 | 09:50 AM
Z064life's Avatar
Z064life
St. Jude Donor '06
shopman1
Are you on GRUMPY'S hit list?
Old Mar 22, 2005 | 09:53 AM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
that's a strange problem..I'll send this to the help section
Old Mar 22, 2005 | 09:55 AM
BlaznZ06's Avatar
BlaznZ06
Maybe their starting to eliminate anyone with a front license plate mounted to their car.
Old Mar 22, 2005 | 11:12 AM
TedG's Avatar
TedG
I actually have the same problem. I bought a new computer and when it tries to load the C7.JPG it messes up all images to follow. The short term fix is to select another generation and restart your browser. I have had Tracy have try looking into this. It works okay on my computer at work, but my new HP 17" laptop is having that problem.
Old Mar 22, 2005 | 12:33 PM
Arthur6's Avatar
Arthur6
That's funny....
Old Mar 22, 2005 | 08:14 PM
RichF's Avatar
RichF
St. Jude Donor '03, '04 & '05
shopman1
Have you tried "resetting your cookies" ??
Old Mar 24, 2005 | 11:36 PM
TedG's Avatar
TedG
I am now able to use the forum with the C6 theme. I downloaded a Microsoft update. I don't know if the update or the forum got fixed.
Old Apr 8, 2005 | 01:40 PM
Mr. Jones's Avatar
Mr. Jones
Help!
I posted an event in the "Events forum" calender on the wrong date.
April 8 shows an Aug. event. How do I remove it?
I did add the event to Aug. 6 where it belongs.
Is this a moderator fix only? If yes please fix
Old Apr 8, 2005 | 09:04 PM
RichF's Avatar
RichF
Originally Posted by Mr. Jones
Help!
You can edit it yourself (or delete). Go to the appropriate month on the calender, click on your event.. on the right side of the screen, you will see a drop-down menu that says 'event options' .. pick 'edit event' and then you can make the changes..
To I have a problem with the forum
