Help Forum How To | General Corvetteforum Questions | Feedback
C5 tech performance merge again?
Old Apr 8, 2005 | 06:11 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
Default C5 tech performance merge again?
I don't see C5 performance anymore?
Old Apr 8, 2005 | 08:47 PM
Troy Roberts's Avatar
Troy Roberts
CF Co-Founder
Cruise In I Veteran
Cruise In II Veteran
Cruise In III Veteran
Cruise In IV Veteran
Cruise In V Veteran
Cruise In VII Veteran
St. Jude Donor '03-'04-'05-'06-'07
It's still there. I can see it anyway.
Old Apr 8, 2005 | 08:50 PM
Troy Roberts
CF Co-Founder
Cruise In I Veteran
Cruise In V Veteran
Just had a thought. Are you looking at the links in the left column to find it? If so, you need to change your theme to C5 from C6 (which is now the default). You can do that in the upper right hand corner of the forum screen by using the pulldown.
Old Apr 8, 2005 | 09:24 PM
John Shiels
That's what happen I wondered how it got switched. Then the pull down doesn't have it seperate. I feel better now I need not put the crack pipe down yet. Thought I was losing it
Old Apr 9, 2005 | 11:04 AM
Troy Roberts
CF Co-Founder
Cruise In I Veteran
Cruise In V Veteran
The pulldown menu is for the skin you use when you look at corvetteforum. There is one for each generation as well as C5 Z06.
When you choose a skin you get the links associated with that generation in the sidebar and graphics for that generation.
We recently made the default skin C6 instead of C5.
To C5 tech performance merge again?
