Help Forum How To | General Corvetteforum Questions | Feedback
Time and date
Old Apr 27, 2005 | 11:56 AM
AmIBadd's Avatar
AmIBadd
Default Time and date
How do I set the time and date. When I post the time is not correct. I`m in central time if that help.
Old Apr 27, 2005 | 12:23 PM
Leos 81's Avatar
Leos 81
Go to your "User CP" up next to the Forums drop down box up above (below the Corvette Forum banner.) Select "Edit Options" in the Control Panel". About half way down there is a section called "Date & Time Options". You can select Central Time in the appropriate box, and then be sure to select the appropriate daylight savings time setting "Automatically detect DST settings". Hope this helps.
