Help Forum How To | General Corvetteforum Questions | Feedback
Signature
Old May 9, 2005 | 06:28 PM
BowtieDiva70's Avatar
BowtieDiva70
Default Signature
I want to put the picture below in my signature, but I am very confused on how to do it! Any help would be appreciated, and I do not care if this gets moved!
And, somehow, I want it to say BlueAngel!
Thank you!
Old May 9, 2005 | 06:33 PM
ExRedRacer's Avatar
ExRedRacer
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
Thank you!
Hi, Daphne!
Click "User CP"
Click Edit Signature
In the window, simply type "Blue Angel!"
Then post the link to your photo and there you are.
Try it and let's see if it works.
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Greetings Daphne,
You just need to copy and paste the same text including the [IMG][/IMG] that you used to insert the photo here into the box when you edit your signature. Just look under User CP from the top menu, and select Edit your signature and copy the photo info into there.
Paul
Old May 9, 2005 | 06:34 PM
Ginzo's Avatar
Ginzo
Log in, go to "user cp" up top on this site and then enter "edit signature" add photos and text.
Old May 9, 2005 | 06:38 PM
BowtieDiva70
Thank you! It is a work in process!!!!
Old May 9, 2005 | 06:57 PM
MrWhan's Avatar
MrWhan
CI 3-4-5-6-7-8 Veteran
St. Jude '03 thru '26
You can add this to your sig too
To Signature
