Adding info under Avatar?
Dec 21, 2005 | 10:44 PM
I see under certain members they have additional information like location, catchy sayings, mods, etc.
How do you add those to your own avatar to share a little more information about yourself?
DKHIGHPERF
Dec 21, 2005 | 10:49 PM
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
go to User CP
you should be able to fix everything you need from there.
also, there's a help section that these types of questions are supposed to be posted in.....
http://forums.corvetteforum.com/zeroforum?id=31
There are moderators that regularly scan the help forum, and should beable to get an answer to you fairly quickly.
Welcome to the forum!
Chris
Dec 21, 2005 | 10:55 PM
Danka
Thanks. I'm not new. Just Ignant
DKHIGHPERF
Dec 21, 2005 | 10:57 PM
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Quote:
DKHIGHPERF
We were all new once
Dec 21, 2005 | 11:13 PM
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Quote:
You still are.
Dec 21, 2005 | 11:48 PM
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Here here!
Dec 21, 2005 | 11:53 PM
Dec 22, 2005 | 02:28 AM
St. Jude Donor '11
Quote:
Originally Posted by lager99
You still are.
mang...I even felt that one
Dec 22, 2005 | 08:23 AM
St. Jude Donor '05, '12-'13, '15-'16, '21
You still are.
Smack
Dec 22, 2005 | 08:31 AM
CI 3-4-5-6-7-8 Veteran
St. Jude '03 thru '26
Quote:
Originally Posted by Stangkiller
go to User CP
Typically it's done with User CP, Edit Profile, and the sayings are put in the City and State fields.
