Help Forum How To | General Corvetteforum Questions | Feedback
Flash in sig?
Old Jan 31, 2006 | 07:42 AM
Ucraz-E's Avatar
Ucraz-E
Default Flash in sig?
Can I use a flash file for my sig ? if so, is there a certain way to do it.
Thanx for the help
Old Jan 31, 2006 | 09:29 AM
MrWhan's Avatar
MrWhan
CI 3-4-5-6-7-8 Veteran
St. Jude '03 thru '26
I don't know of a way to add flash to a sig. I played around a little, but since you can't add full html code, you are limited to certain image files only.
Old Jan 31, 2006 | 10:14 AM
Ucraz-E's Avatar
Ucraz-E
hmm....ya I just don't get it. I'm hosting it elsewhere but i'm just getting a X here. So the lack of html code is killing it?
Old Jan 31, 2006 | 10:49 AM
MrWhan's Avatar
MrWhan
I believe so. Plus it may rely on the local machine having java, flash, etc.
I have seen some sites you can link to trick the local system and create things in PNG format that you can then link between IMG tags.
But flash wasn't one that I found.
Old Jan 31, 2006 | 11:54 AM
Ucraz-E's Avatar
Ucraz-E
OH well....Thanx for the info though
Old Jan 31, 2006 | 12:00 PM
MrWhan's Avatar
MrWhan
If you find something....
Old Jan 31, 2006 | 04:51 PM
Ucraz-E's Avatar
Ucraz-E
To Flash in sig?
