Go to the HELP section and ask for a name change in the title of your post. PM should be okay instead.
It is your responsibility to keep the information in your profile up-to-date. You should especially ensure that your email address is kept current. You can alter any of the fields in your profile, except your username. Once you have registered your username, it becomes yours for life. In extreme circumstances, you may request that the administrator change your username, but he or she will require a very good reason to do so.
I could be stuck!
Nah, just give me the name you want, I will forward it to the admins who will see if the name is available. If it is, then they will change it.
