is there any way i can tell where a thread has been moved to? i realize that some posts are in the wrong section,but sometimes i dont know how to find one that has been moved..thx, jim...
The moderator can move, copy, or "move with redirect".
Just moving typically goes to the boneyard where threads are removed due to violations.
Copies are done sometimes between stickies across sections.
Moved with redirect should still have the link in the original section. When you click that link, it should take you to the new area it was moved.
It is the discretion of the moderator doing the "moves" to decide which one to use. If they move without a direct, then you will have to use your best guess where it went or PM a moderator of that section.
