Help Forum How To | General Corvetteforum Questions | Feedback
Thumbnails / Sig Pixs??
Old Apr 2, 2006 | 07:41 PM
Donne Trav's Avatar
Donne Trav
Default Thumbnails / Sig Pixs??
SORRY, but I didn't know where this thread should be posted.
First, what are "sig pix" and where do they show up? Second, I just tried
adding a "thumbnail photo" to show up on NEW THREADS, etc. It didn't
show up. Instead, it showed up on "MY PERSONAL PROFILE" page. How is
this done or where is the info on this matter? THANKS
Old Apr 2, 2006 | 08:06 PM
Midnite 88's Avatar
Midnite 88
Thumbnail is for your avitar. Mine is the "Black Sheep" thing to the left.
Sig pic is below.
Old Apr 2, 2006 | 08:09 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
I moved this into the "HELP" section.
Sig pics are in your sig, in order for themto show you have to attach your sig when you post(not necessary or recommended for every reply).
As far as getting the pic to show once you've done that, look at the top of this section on "posting pics". That will steer you inthe right direction.
Thumbnails are the same a s regular pics except that you have to include the link to the full soze pic when you write the code for the thumbnail. That should be covered in one of the pic posts as well.
If you become a supporting member, that will give you the ability to post attachments. That way you won't need webspace to host your pics.
Old Apr 2, 2006 | 08:11 PM
CSS996's Avatar
CSS996
Below the box where you type your reply is a grey line that says "Additional Options". Below that is a box where you can check "Show your signature". You need to check that box or your sig. will not show up. From what I have learned, you have to check that box every time you want your sig. to show up. I guess it's a good idea for those folks that have a larger picture in their sig. Me, I just have a little bit of text... Hope that helps.
To Thumbnails / Sig Pixs??
