Help Forum How To | General Corvetteforum Questions | Feedback
** Issues Being Worked - expect Changes [AOL Users]***
Old Apr 5, 2006 | 11:27 AM
MrWhan's Avatar
MrWhan
CI 3-4-5-6-7-8 Veteran
St. Jude '03 thru '26
Default ** Issues Being Worked - expect Changes [AOL Users]***
**** UPGRADE ISSUES BEING WORKED -EXPECT CHANGES ***
Please be patient as the moderators, admins, and techies work thru issues after the upgrade.
Old Apr 7, 2006 | 11:58 AM
MrWhan's Avatar
MrWhan
Originally Posted by admin
Something about the software upgrade is in conflict with AOL users. I probably have 450 Forum Support e-mails I'm trying to work through because their passwords aren't working.
Logon and Logoff Issues being worked....
Old Apr 7, 2006 | 12:01 PM
MrWhan's Avatar
MrWhan
Originally Posted by fl_rider
I went to User CP and clicked on Paid Subscriptions and it says I am not authorized.
Please advise.
Thanks,
Chris B
Originally Posted by phewitt
I have submitted this issue to Mantis (Intechnic). They're on the case.
Issue being worked with High Priority
Old Apr 7, 2006 | 12:02 PM
MrWhan's Avatar
MrWhan
Originally Posted by 98Pace97Coupe
Picture, smiley and avatar issues are accumulating here...http://forums.corvetteforum.com/show....php?t=1356362
OK...this has been escalated to high priority.
Hopefully a solution is found quickly.
High priority set for this issue...
Old Apr 10, 2006 | 08:06 AM
MrWhan's Avatar
MrWhan
If you use AOL Browser, switch to Internet Explorer to access the forum.
If you are having issues with Internet Explorer, try using a different browser ( ie Firefox ).
Most of the issues may have to do with cookies. Sometimes clearing them from your tools options in your browser will fix the issues. If it doesn't, then that is when you may need to switch to another browser and try that.
You may also want to try a freeware tool to clear these out also. I have used Crapcleaner to do this.
Thanks for your patience as the techies work the issues
To ** Issues Being Worked - expect Changes [AOL Users]***
