Help Forum How To | General Corvetteforum Questions | Feedback
Problem with Pms
Old Apr 10, 2006 | 12:10 PM
GO4URS's Avatar
GO4URS
St. Jude Donor '09-'11-'12
Default Problem with Pms
I am having an issue with sending private messages. I sent one yesterday and there is no record of the message in my "Sent" folder.
Am I the only one???
Old Apr 10, 2006 | 12:35 PM
MrWhan's Avatar
MrWhan
CI 3-4-5-6-7-8 Veteran
St. Jude '03 thru '26
You must select the "Save Sent" check box below the PM edit window each time...
Old Apr 10, 2006 | 03:01 PM
GO4URS's Avatar
GO4URS
Aw...thank you!!!
Old Apr 10, 2006 | 03:24 PM
MrWhan's Avatar
MrWhan
Aw...thank you!!!
Old Apr 17, 2006 | 12:34 AM
VenkmanP's Avatar
VenkmanP
I just came over here to post about this same issue. It used to save them automatically. Not sure when it changed, but it's really annoying that I now lose most of my outgoing PMs.
I've looked around and can't find a way to set it to default to saving them.
Based on your reply, I guess there is no way to do that?
Old Apr 17, 2006 | 11:27 AM
MrWhan's Avatar
MrWhan
That is correct, it was changed in December to NOT save sent and you must do it manually. It has been suggested in the Steering Committee to reconsider, but it is up to Troy (and right now he's busy with the upgrade issues).
Old Apr 17, 2006 | 11:28 AM
VenkmanP's Avatar
VenkmanP
Thanks for the info.
To Problem with Pms
