Help Forum How To | General Corvetteforum Questions | Feedback
Whats up here ???
Old Apr 10, 2006 | 11:47 PM
talldude67's Avatar
talldude67
Default Whats up here ???
Any one else having trouble pulling up the [C6 General] forum on the net???? Sent in $25 for the yr and then this happens...all screwed up, no dealer pics on the lt side, text is way off..NO smilies..HELP...
Old Apr 10, 2006 | 11:58 PM
VamPY's Avatar
VamPY
Works fine here. Probably its a problem with ur browser. Try another browser such as firefox.
Old Apr 11, 2006 | 12:37 AM
Zymurgy's Avatar
Zymurgy
Moderator
Forum seems to work the best when using IE. Various problems have been reported with other browsers.
Old Apr 11, 2006 | 12:47 AM
silvertc6's Avatar
silvertc6
No problems here.
Old Apr 11, 2006 | 01:31 AM
VamPY's Avatar
VamPY
Unless if his IE is corrupted as often happens.
Try to re-instll IE or whatever browser ur using. Also see if you have an malicious software that might be causing this
Old Apr 11, 2006 | 01:56 AM
lexaudio's Avatar
lexaudio
Firefox and IE fine here.
LEX
djfullshred's Avatar
djfullshred
For the longest time this site was all screwed up on my home PCs browser. Not too long ago, it all seemed ok again. I made no changes on my PC, so I was assuming they updated something on their end.
Old Apr 11, 2006 | 02:05 AM
lexaudio's Avatar
lexaudio
What is you OS, OS version and Browser version.
You may need to check your preferences in your browser.
LEX
Old Apr 11, 2006 | 02:30 AM
VamPY's Avatar
VamPY
LEX
and if you are at work or behind a firewall that might be also a potentional cause
Old Apr 11, 2006 | 02:31 AM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
Boo Hoo it work fine try the help section
Old Apr 11, 2006 | 02:44 AM
JELSIS's Avatar
JELSIS
Theres been alot of problems after the forum upgrade/update a few days ago, I was having the same problems "no pics, avatars, reply keys, forum dealer ads and no smilies" I use optimum online with IE and it does not work with this forum anymore, the techs are supposed to be working on a fix. For the time being I downloaded Firefox 1.5 and everything on the forum is working fine.
Old Apr 11, 2006 | 02:50 AM
pennys58's Avatar
pennys58
SC CF Senior Member
St. Jude Donor '06-'07-'08
I am having a problem reading the text. Everything is blank, and I have no clue what anyone is actually talking about. Nevermind, my eyes just keep closing because my brain understands I need to be up in 3.5 hours. My bad!
Old Apr 11, 2006 | 10:21 AM
ByByBMW's Avatar
ByByBMW
St. Jude Donor '06-'08-'10-'11-'12-'13 '14-'15-'16-'17-'18-'19
I am having problems with Mac OSX 10.4.6 and safari. My PC with firefox works much better than Safari.
Old Apr 11, 2006 | 10:45 AM
User 81424's Avatar
User 81424
ttt
Old Apr 11, 2006 | 10:50 AM
MrWhan's Avatar
MrWhan
CI 3-4-5-6-7-8 Veteran
St. Jude '03 thru '26
If you use AOL Browser, switch to Internet Explorer to access the forum.
If you are having issues with Internet Explorer, try using a different browser ( ie Firefox ).
Most of the issues may have to do with cookies. Sometimes clearing them from your tools options in your browser will fix the issues. If it doesn't, then that is when you may need to switch to another browser and try that.
You may also want to try a freeware tool to clear these out also. I have used Crapcleaner to do this.
Thanks for your patience as the techies work the issues
Old Apr 11, 2006 | 11:29 AM
Mel 2001's Avatar
Mel 2001
Try logging out, then log back in. Worked for me.
Old Apr 11, 2006 | 09:40 PM
VamPY's Avatar
VamPY
or refreshing + deleting history and as many have said maybe try some free cleaner software such as SpyBot S&D or ADaware
To Whats up here ???
