Help Forum How To | General Corvetteforum Questions | Feedback
Viewing posts
Old Oct 27, 2006 | 02:40 PM
300Z51's Avatar
300Z51
Default Viewing posts
Why is it that not all posts are viewable w/o clicking "replies below current depth?"
Old Oct 27, 2006 | 04:30 PM
MrWhan's Avatar
MrWhan
CI 3-4-5-6-7-8 Veteran
St. Jude '03 thru '26
I'm not sure what you mean...are you using the Linear Mode option under Display Modes?
Old Oct 27, 2006 | 04:43 PM
300Z51's Avatar
300Z51
I am using linear mode. What I mean is that I can submit a post, but when I go back to click on the thread, that post is not always there. However, if I go scroll through that pane right above the thread, I can click on where it says "replies below current depth" and see the post.
Old Oct 27, 2006 | 05:59 PM
MrWhan's Avatar
MrWhan
It still sounds like your display mode is "threaded", not linear.
Can you confirm based on the below example that you indeed are Linear?
Old Oct 27, 2006 | 06:13 PM
300Z51's Avatar
300Z51
Problem solved! Thanks a million
Old Oct 27, 2006 | 06:56 PM
MrWhan's Avatar
MrWhan
To Viewing posts
