Help Forum How To | General Corvetteforum Questions | Feedback
Private message?
Old Oct 29, 2006 | 11:47 AM
LITE SPD's Avatar
LITE SPD
2nd Gear
Default Private message?
I'm new to this forum and I can't send a private message. Why?
Old Oct 29, 2006 | 11:51 AM
MrWhan's Avatar
MrWhan
CI 3-4-5-6-7-8 Veteran
St. Jude '03 thru '26
You may need to describe what is happening when you do try. Once you are approved to post on this forum, you should be able to send PMs.
I sent one to you. Reply back and we can go from there...
Old Oct 29, 2006 | 11:57 AM
LITE SPD's Avatar
LITE SPD
2nd Gear
I just tried to send a PM to Flareside and I don't believe it worked.
Old Oct 29, 2006 | 12:03 PM
MrWhan's Avatar
MrWhan
Below the PM edit window is a checkbox to "Save Sent" items. You may want to check that next time you send one so you can have a record.
If that forum name is not valid, it will tell you.
Otherwise, you can check the "get receipt" option from the popup you get once you do submit. You will get an inbox confirmation when the receiving person reads it (assuming they confirm to send that receipt).
If unsure, next time add a semi-colon and your own forum name and try that. That way you can see if you are sending out PM's.
To Private message?
