I've been a member for a while and I still not know how to post pictures. I know there is a thread somewhere. Can someone direct me to the instructions?
Thanks.
go to photobucket.com, register, go to your album...upload it, thencopy the IMG CODE OR URL LINK then copt n paste.
As a supporting member, when you create a post, there will be an additional button under the box you're using to enter your text. It's labeled "Manage Attachments." When you're through entering text, click that button and it will let you search your harddrive for pics you want to post (up to a certain size). After you've found the pic and clicked on it, click on the UPLOAD button and follow the directions. It will appear in the post after you submit your post.
Optionally, you can host the pic somewhere on the web and just paste info about the location in your post as per the attached link.
I think you're talking about an avatar. Click on USER CP, then EDIT AVATAR and follow the instructions. It's been too long since I've done it, but it should be quite similar to my instructions for how to post a pic if you're a supporting member. The pic you use for an avatar has a maximum size of 150 pixels X 150 pixels. It can be a pic on your harddrive.
And there are plenty of sticky threads in this section for those other types of pics too
