Help Forum How To | General Corvetteforum Questions | Feedback
Signature
Old May 8, 2007 | 12:22 PM
Bob88Convertible's Avatar
Bob88Convertible
Default Signature
Can you tell me why my sig does'nt show up in my posts?? Thanks.
Old May 8, 2007 | 02:17 PM
MrWhan's Avatar
MrWhan
CI 3-4-5-6-7-8 Veteran
St. Jude '03 thru '26
You must check the "Show my signature" check box below the posting edit window. Look for the box Miscellaneous Options below.
Etiquette is to show your signature once per thread.
Old May 12, 2007 | 02:28 PM
JETSWU87's Avatar
JETSWU87
test
Old May 24, 2007 | 01:57 PM
Bob88Convertible
Ok, got it, thanks.
Old May 24, 2007 | 02:06 PM
MrWhan's Avatar
MrWhan
Ok, got it, thanks.
Old May 30, 2007 | 03:18 AM
Vette_Drvr's Avatar
Vette_Drvr
I selected that but still no sig? when I open up "edit sig" at the bottom it sas "no" for the upload images for sig?! Is this an "earned" privalege?
Old May 30, 2007 | 06:41 AM
MrWhan's Avatar
MrWhan
You selected the "Show your signature" checkbox below in the Miscellaneous Options section?
Old May 31, 2007 | 09:32 PM
Vette_Drvr's Avatar
Vette_Drvr
Can't find this box...is it in the "edit signature" tab or the "edit options"?
the only "show signature I found was in "edit options" under "thread display"; the "edit signature" tab just has a signature permission tab under the block where you save or view your sig....and has a "no" next to the "upload image for signature"
Old Jun 1, 2007 | 07:26 AM
MrWhan's Avatar
MrWhan
Did you see my attachment pic above showing you where it is?
When you are typing a post such as I am doing now, the "Show your signature" check box is below the edit window you are typing in...scroll down past the Submit reply as shown in the attachment above.
Old Jun 1, 2007 | 09:06 PM
Vette_Drvr's Avatar
Vette_Drvr
OH!!!!! Dang I'm REALLY computer illiterate...OK I'm stupid ...wow that's the ol' if it were a snake...Thanks!!!
Old Jun 1, 2007 | 10:32 PM
USA1C5's Avatar
USA1C5
My signature not showing up also. I'm trying it again
here. I did check the Show your signature box.
Old Jun 1, 2007 | 10:34 PM
USA1C5's Avatar
USA1C5
I'm quoteing myself here. I still have no Signature.
Can anyone help me?
Old Jun 1, 2007 | 11:22 PM
MrWhan's Avatar
MrWhan
Old Jun 1, 2007 | 11:24 PM
MrWhan's Avatar
MrWhan
It appears in this post, not in the one you had below it.
If you are not seeing it, and if you are not seeing the others, you need to go to UserCP, Edit Options, View Visible Post Elements and make sure all are checked.
Otherwise, you will need to check the "show sig" each time you post in order to have it appear.
Old Jun 1, 2007 | 11:44 PM
USA1C5's Avatar
USA1C5
Thank You, Thank You, Thank You. I did what you said
and now I see my Signature.
Old Jun 2, 2007 | 08:28 AM
MrWhan's Avatar
MrWhan
Old Jun 27, 2007 | 08:29 PM
NHRA_TA's Avatar
NHRA_TA
St. Jude Donor '10
Test
To Signature
Old Sep 5, 2007 | 07:56 PM
pTr73's Avatar
pTr73
Testing my sig, was having a problem until i found this thread! Hope it helps!
Old Sep 5, 2007 | 08:14 PM
MrWhan's Avatar
MrWhan
Old Sep 24, 2007 | 10:27 AM
turbo-max's Avatar
turbo-max
+1 thanks!
