Help Forum How To | General Corvetteforum Questions | Feedback
Forum Problems - Unable to login/DB Errors
Old May 15, 2007 | 07:53 PM
JeremyT's Avatar
JeremyT
Default Forum Problems - Unable to login/DB Errors
I'd say there is certain a forum issue. I couldn't log in this afternoon from a machine. It was not my machine, nor browser. I tried FireFox and IE. Both would allow me to login, gave me the "thank-you" message, but then immediately would redirect me back to the login page.
I'm only able to post this (logged in) because I'm using a different machine which already had me logged in.
It wouldn't be a problem for me, had the forums not been set up so you cannot search without being logged in. Not being able to login, meant the search wasn't available. If the Admins are concerned about server load and unnecessary searches, why not use the "image verification string" for non-logged in users if you want to reduce server load and restrict searches to only valid ones?
Earlier this afternoon, the forums was producing a database error message. It was a mysql error for the session table being full.
Old May 15, 2007 | 08:15 PM
MrWhan's Avatar
MrWhan
CI 3-4-5-6-7-8 Veteran
St. Jude '03 thru '26
fubar.
Using firefox I have had to go to Tools/Options/Clear all data on each section I want to go to.
Good luck, and may the force be with you!
Old May 15, 2007 | 08:58 PM
JeremyT's Avatar
JeremyT
Got locked out again with more database errors from this forum. The error was:
Code:
Database error in vBulletin 3.6.2:
Invalid SQL:
				INSERT IGNORE INTO session
					(sessionhash, userid, host, idhash, lastactivity, location, styleid, languageid, loggedin, inforum, inthread, incalendar, badlocation, useragent, bypass, profileupdate)
				VALUES
					('60a2298fb6d0ac9c774fd8defc24f051', 215968, '167.142.36.92', '50a6718133e6c6f7a34e17c1055743be', 1179276202, '/', 4, 0, 1, 0, 0, 0, 0, 'Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.1.3) Gecko/20070309 Firefox/2.0.0.3', 0, 0);
MySQL Error  : The table 'session' is full
Error Number : 1114
Date         : Tuesday, May 15th 2007 @ 07:43:29 PM
Script       : http://forums.corvetteforum.com/
Referrer     :
IP Address   : xxx.xxx.xxx.xxx
Username     : JeremyT
Classname    : vb_database
Old May 15, 2007 | 09:37 PM
gr8whte's Avatar
gr8whte
St. Jude Donor '05-'06-'07-'08
Code:
Invalid SQL:
				VALUES
Error Number : 1114
Referrer     :
Username     : JeremyT
It says its full, its its way of sayin GTFO Just kiddin, check out this thread for some help http://forums.corvetteforum.com/show....php?t=1705654
To Forum Problems - Unable to login/DB Errors
