WellAdjusted memorial Avatar won't load
Jul 10, 2007 | 09:35 PM
From: Top of the hill, 3rd mailbox on the right. Texas
CF NCM Ambassador
CI 6-7-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10
NCM Member '09
I made an avatar to memorialize Mike Holt at the request of a couple of folks. I can get it to load but they can't.
Any thoughts? If you can make this work for Gray Fox I know Mary would deeply appreciate it.
Jul 10, 2007 | 11:42 PM
St. Jude Donor '06
Quote:
Originally Posted by
BuckyThreadkiller
It's too big - 25065 K
Note: The maximum size of your custom image is 150 by 150 pixels or 24.4 KB (whichever is smaller).
Let me see what I can do
Jul 11, 2007 | 12:06 AM
St. Jude Donor '06
Either of these resized .gifs will work for you as a Gold Member.
You have to be a mod, regional or Gold member to use animated .gifs
Maybe Jesse will give them a pass on this.
Re the pics:
Two rotation rates - 2 seconds and 5 seconds.
They are both well below the size limit.
I took your middle layers out - 2 and 4.. There just wasn't a way to keep them and stay under the size limitations of the Forum.
Chris
Jul 11, 2007 | 12:33 AM
CI 5-6-7-8-9 Veteran
I tried the images above, they will save but the animation won't work
I am a regional coordinator
Jul 11, 2007 | 12:41 AM
St. Jude Donor '06
Gray Fox
Hi Gray Fox,
Is the avatar that you currently show one of the ones that I posted?
Don't take this the wrong way, but are you saving them as a .gif?
If so, I don't know why it wouldn't work, but I can't validate it for you because I'm not a Gold member/mod/regional.
Maybe Jim can try it and see if his results as a Gold (only obvious difference between your avatar posting and his) help.
Jul 11, 2007 | 12:47 AM
St. Jude Donor '06
I tweaked the transparency on this one - I don't think this is the issue, but you could try it.
I'm sorry I don't have any other bright ideas...
GL with this - I'm off to bed. Night.
Jul 11, 2007 | 01:30 AM
HIRISC
I used your image link, and it still wont animate
Maybe Ron can help out in the morning. I'm off to bed too.
Thanks guys.
