Help Forum How To | General Corvetteforum Questions | Feedback
Moderators, a little help please
Old Oct 3, 2007 | 01:05 AM
Bluefire's Avatar
Bluefire
Default Moderators, a little help please
How do you get this (deleted expletive) search engine to search for more than one word at a time.
For example: I want to search for "force motor current". I put those words in the advance search filter and it pulls up every thread with the word "force" in it, and every thread with the word "motor" in it, and every thread with the word "current" in it.
I have tried using "force&motor&current" and "force+motor+current". Neither work. Please inform me of the secret key to do a meaningful search and dispell my belief that this search engine is a POS.
Thank you.
Old Oct 3, 2007 | 01:10 AM
unionlandlord's Avatar
unionlandlord
C5 General
From: Boosted in Manhattan & Round Rock TX. President of the Non Club Club of Kansas and Round Rock , Not the flat part.
Do you have any Pics?
Paul G.
Old Oct 3, 2007 | 01:14 AM
Bluefire's Avatar
Bluefire
Paul G.
Put the pipe down.
Old Oct 3, 2007 | 01:29 AM
WetteVette's Avatar
WetteVette
I share your frustration. I too have all but given up on using the search engine on this Forum. It leaves much to be desired. And I have been using Internet search engines for over 12 years. Have ALWAYS been able to find what I was looking for.
Old Oct 3, 2007 | 01:33 AM
Junkman2008's Avatar
Junkman2008
Thank you.
If the search engine is working properly, then the boolean phrase that you're entering should work. Computers are my thing so this is the way it SHOULD work.
If you type in force motor current, you should get back every page with the words force, every page with the word motor, and every page with the word current. However, doing a search for force+motor+current should bring back only the pages with those 3 word on them in no specific order. Using quotations as in "force motor current" should bring back ONLY the pages with that exact phrase. Furthermore, + is the same as &, and leaving a space between each word is also the same as + or &.
Lastly, doing a search for motor -engine should bring back every page with the word motor, as long as that page does not contain the word engine. This is the way every search engine on the Internet works, however, I have found mixed results with the forum's search engine. This can be attributed to the template that the powers that be have chosen to run, an is what we use to interact with each other.
What I suggest you do is learn the Ctrl+F function which will allow you to search with a page and assist you in figuring out whether or not a document that you're looking at is relevant to your search. I find it to be a little tedious doing searches on this forum but if you get creative enough or ask after you've exhausted the search engine, someone will come through for you.
Old Oct 3, 2007 | 02:34 AM
Bluefire's Avatar
Bluefire
Thank you for the response. I tried the using the "forced motor current" and it returned something to the effect of "Sorry nothing found" in the Advanced Search page. In the Key word(s) field on that page it had placed the phrase "forced*motor*current". Then I tried just using the forced*motor*current format. It found a 36 posts and none of them had that phrase highlighted in red, or had anything to do with force motor current. I too have sucessfully used many search engines in the past and am familiar with the CTL-F find function. I quess I will just ask the question I have on the forum and try to politely ignore the "Did you do a search?" questions. Thanks again.
Old Oct 3, 2007 | 02:41 AM
LoneStarFRC's Avatar
LoneStarFRC
How about the possibility that the phrase "forced motor current" is simply not in any of the Corvetteforum's databases?
Old Oct 3, 2007 | 02:47 AM
flynbya2's Avatar
flynbya2
St. Jude Donor '05-'06
Don't take offense,but just to make sure,are you checking in the archives as well?
You probably are,but if not it may help
Bluefire's Avatar
Bluefire
That is a possbility. I just thought that with "force motor current" being one of the parameters that can be adjusted in the 4L60E A4 transmission that there was a likely probability someone in the Scan and Tune section would have mentioned it.
Old Oct 3, 2007 | 02:51 AM
Bluefire's Avatar
Bluefire
No offense taken. I actually have not checked there yet. I am heading there now. Thank you.
Old Oct 3, 2007 | 02:54 AM
flynbya2's Avatar
flynbya2
I can't begin to tell you of the countless times I have used the search with a "no match result"
Then when I checked the archive button also, TONS of things come up!
Good luck
Old Oct 3, 2007 | 03:15 AM
Bluefire's Avatar
Bluefire
Good luck
Believe it or not, the archives did net a few results. Must be very few people here that ever mention it.
Old Oct 3, 2007 | 03:20 AM
Junkman2008
OKAY! Now show the rest of us forum dummies where this archive section is! I never knew there was one!
Old Oct 3, 2007 | 08:21 AM
BudgetPlan1's Avatar
BudgetPlan1
St. Jude Donor '09-'10
It's a checkbox in the section "Search In" at the bottom of the search page. Options are Current, Archive or you can check both to search in all locations.
Old Oct 3, 2007 | 08:35 AM
jdmvette's Avatar
jdmvette
Night Owl for life
Old Oct 3, 2007 | 09:27 AM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
did you try the help section. That is a good place to start.
Old Oct 3, 2007 | 09:32 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
To Moderators, a little help please
Old Oct 3, 2007 | 10:02 AM
z06Bigbird's Avatar
z06Bigbird
Help. Can I have some help finding the help section?
LOL
Old Oct 3, 2007 | 10:25 AM
IrishMac's Avatar
IrishMac
Moderator Emeritus
Gone, but not Forgotten
Cruise-In 5, 6, 8 & 10 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09
Of to Ron's place.
Old Oct 3, 2007 | 10:39 AM
MrWhan's Avatar
MrWhan
CI 3-4-5-6-7-8 Veteran
St. Jude '03 thru '26
Originally Posted by IrishMac
Of to Ron's place.
...he's not home...
