Help Forum How To | General Corvetteforum Questions | Feedback
Num lock key
Old Apr 19, 2008 | 06:42 AM
Casper's Avatar
Casper
Default Num lock key
How do you put the Num Lock key where it will stay locked? TIA
Old Apr 19, 2008 | 06:01 PM
Topless's Avatar
Topless
Cruise-In IV Veteran
St. Jude '03-'04-'05-'06-'07-'08
Depends on the computer. Some you have to set it in the BIOS.
If you're comfortable running scripts on your computer, MS has a script you can run to set Num Lock ON as default every time your computer starts -- if you're using WinXP. http://support.microsoft.com/kb/314879
Or you can change the registry: http://support.microsoft.com/kb/154529
Old Apr 19, 2008 | 07:47 PM
c4cruiser's Avatar
c4cruiser
My Gateway standard keyboard has a NumLock key (above the "7" key on the numeric keypad and the indicator light stays on even after a reboot.
I use the keypad a bunch for Excel stuff and I didn't have to do anything but press the NumLock key once to lock it "ON" so tha the indicator light comes on and that's where it stays.
To Num lock key
