Help Forum How To | General Corvetteforum Questions | Feedback
po410
Old Sep 9, 2008 | 05:41 AM
Pappa's Avatar
Pappa
8th Gear
Default po410
The pump is running the check valves are working. The air flow seems low how much air should be coming from the pump? Should it be a strong flow or low flow?
Old Sep 9, 2008 | 06:25 AM
MrWhan's Avatar
MrWhan
CI 3-4-5-6-7-8 Veteran
St. Jude '03 thru '26
This is a technical question best directed to one of the Tech/Performance sections of the forum based on the generation Vette you own. I would move it for you, but I don't know what model you own.
