Help Forum How To | General Corvetteforum Questions | Feedback
Help changing from mobile
Old Aug 6, 2009 | 10:45 PM
steelcities's Avatar
steelcities
Default Help changing from mobile
I changed my forum to mobile interface for my blackberry but it changed my laptop, too. And now, I can't get back to options to change it back.
Any help?
Thanks.
Old Aug 6, 2009 | 10:58 PM
J T's Avatar
J T
IB Staff
Any help?
Thanks.
Depends on what style you was using (based on the Corvette generations):
C2
C3
C4
C5
C5 Z06
C6
C6 Z06
C6 ZR1
I suspect you initially changed the style in your UserCP. When that is done, it's set to your account. If you select the style via the drop-down menu in the lower left corner of every page, it's done via cookies.
You will want to use the above links with your laptop to temporary get the full-version style. Then, still using the laptop, go into the UserCP - Edit Options and then select the Forum Skin style (last option on the page) with one of the full-versions.
Then, using your phone, revisit this page and select this:
Mobile Style
Now, whenever you visit with your laptop, or any new device, you will get the full-version by default as defined in your account. But whenever you visit with your phone, you will see the Mobile style as it was set via cookie.
In short, changes made in the UserCP are permanent to the account. Changes made via the drop-down menu in the lower left corner are temporary based on browser cookies.
Old Aug 7, 2009 | 11:54 PM
steelcities
Thanks!
To Help changing from mobile
