Help Forum How To | General Corvetteforum Questions | Feedback
Anybody Else Having this Issue?
Old Sep 25, 2009 | 07:06 PM
bapd77's Avatar
bapd77
Default Anybody Else Having this Issue?
All of a sudden when I go to the "forums" tab and go to C6 Corvettes, the menu for General, parts, tech, etc. doesn't come up, but a small little box in the upper left corner comes up with just the letters "Ge.." for General Discussion. What's up with that?
Old Sep 25, 2009 | 07:11 PM
vetsvett's Avatar
vetsvett
I think its your computer. or connection. clear your internet cache, rid your system of all junk/temp files, and defrag.
I'm no expert, but you ought to try that first.
Old Sep 25, 2009 | 07:16 PM
rlperry13's Avatar
rlperry13
I'm having a very similar problem.
Old Sep 25, 2009 | 07:23 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
The board had "issues" earlier. It seems to be working ok for me now. It wasn't very user friendly earlier.
Elmer
Old Sep 25, 2009 | 07:31 PM
Vette_DD's Avatar
Vette_DD
Yes, but we're posting about it in the HELP forum where we're supposed to post things like this.
http://forums.corvetteforum.com/help-forum-31/
Old Sep 25, 2009 | 07:32 PM
Vette_DD's Avatar
Vette_DD
No, it's a real problem.
Old Sep 25, 2009 | 07:36 PM
dvilin's Avatar
dvilin
Same problems trying to access the car care forum.
Old Sep 25, 2009 | 08:10 PM
Tact's Avatar
Tact
Former Law Dawg Moderator
CF St. Jude Co-Organizer
St. Jude Donor '05 thru '24
Hold down the Ctrl button and press F5. See if that clears it up.
Old Sep 25, 2009 | 08:55 PM
Vette_DD's Avatar
Vette_DD
It seems to be working okay now without the special keystrokes.
Old Sep 25, 2009 | 09:56 PM
dreamer2468's Avatar
dreamer2468
St. Jude Donor '09-'10-'11
I am having the same problem, and I tried what you suggested and it didnt work. Any other suggestions?
Also, when I go into my profile, the formatting has changed, was that done and I didnt know about it?
It now looks like file folders with a pencil like icon next each entry on my main profile page on each individual page.
Laura
Old Sep 26, 2009 | 01:17 AM
bapd77's Avatar
bapd77
That fixed it for me!
Old Sep 26, 2009 | 02:41 PM
Vette_DD's Avatar
Vette_DD
Laura
See the other thread on this subject. It suggests you clear your browser's cache. Firefox on my PC is set to automatically clear the cache when I exit Firefox. That's probably why I'm not having the problem.
Old Sep 27, 2009 | 10:59 AM
vetsvett's Avatar
vetsvett
gee, maybe it was a real problem after all.
Old Sep 27, 2009 | 12:43 PM
stingray6507's Avatar
stingray6507
I think this should work for windows users. I had the same problem and did the following: Go to the "start button" in the lower left hand corner of the screen and open. Go to "control panel" and click. Then click on "ïnternet options". Then go about half way down and you'll see "browsing history". There you click on delete and this should help. Also there is a small box you can "check" that says " delete browsing history on exist". This will eliminate the need do go through this regularly. I hope this helps.
Old Sep 27, 2009 | 02:59 PM
J T's Avatar
J T
IB Staff
I'm not an IE guy, but according to Microsoft's documents, that will delete the links in the address bar of sites you visited - not the cache where the files are stored on your hard drive. You want the Delete Files option, not Delete History.
Reason why it may have appeared to work for you, is you may have a low cache setting and just browsing some sites would have overwritten the previous copy of CF you had in your cache.
Old Sep 27, 2009 | 04:30 PM
stingray6507
You know alot more about this then me. I had the same problem with the sight as the original post and went throught the route I suggested. I used the delete history because it gets rid of temporary files. But you are correct, because I do have a low cache setting and I don't browse that much.
Old Sep 28, 2009 | 02:35 AM
dreamer2468
I did what stingray had suggested and it still didnt work, so I did what you suggested, and its all good!
Thanks so much for all of your help. It was so frustrating to have to go to the general forum, then when I wanted to go to another section, I had to start all over again and it took forever!
Thanks again!!!
Laura
To Anybody Else Having this Issue?
